Hello
I am thinking about re-positioning and replacing my gas boiler and would be grateful for guidance.
1. Can a boiler be fixed to lathe and plaster? If not, should the lathe and plaster be removed and a wooden frame attached to the wall for mounting the boiler?
2. Are there any rules re distance of the boiler flue from a cast iron downpipe?
3. Does a flue have to go vertically up and horizontally out through the external wall? Is it possible to offset the flue in order to get a safe distance away from eg cast iron downpipes?
Thank you for any help.
Karen777
