Radiator bleed nipples rounded off
skousa
by skousa » Sat Dec 20, 2008 7:10 am
I have 3 radiators which have rounded off bleed nipples, i have tried pliers but cannot get enough grip on them... please help
nitro23456
by nitro23456 » Sat Dec 20, 2008 1:19 pm
Depends on the type of radiator.
If it is one of the cheap ones where you cant remove the whole bleed assembly you are stuck.
You can try a self tapping screw with ptfe tape as a temporary measure but it is certainly not guaranteed to not leak and the radiator will need replacing.
If you have a better radiator where you can replace the assembly, then the solution is easy - replace it!
Other than this there really are no other options...... although you could try filing a slot in the rounded off nipple so you can fit a flathead screw driver blade in it instead.
I ended up replacing the rad!!
C23kW
by C23kW » Sat Dec 20, 2008 1:23 pm
if u drain the system sumhow then get mayb a set of electrician plier that mayb small enuf for the space. Merchants may sell back up bleeder nipples if u need replacements.
thanks
