by htg engineer »
Sun Feb 22, 2009 8:27 pm
Turn off your mains cold water supply and use the heating, not sure of your system set up -
Combi's if the DHW section is drained and the boiler is still used it may cause damage.
Tank/cylinder, using the hot water the cylinder/tank shouldn't run dry, but as I don't know your system set-up. I would try not to use the hot water or if you do, turn the cold water back on - to replenish the water lost.
htg
