Block paver driveway breaching DPC and causing damp issues
Petebrown2006
by Petebrown2006 » Sun Sep 19, 2021 7:52 am
Hi All,
I have a damp issue due to a block paved driveway breaching the DPC / it was built up and covering air bricks. I have lifted the first 2 rows of brick, to find the base is concrete. Suggestions are that I break the concrete out, excavate and then back fill with 40-50mm stones. The DPC is just above the air bricks shown in the picture
However, to avoid breaking out the concrete do you think the I could drill drainage holes in to the slab instead?
If I do need to break out the concrete, would you suggest a jack hammer?
Re: Block paver driveway breaching DPC and causing damp issues
by stoneyboy » Sun Sep 19, 2021 10:52 pm
Hi petebrown2006
You really need 150mm of exposed brickwork under the DPC. If you cannot achieve this you will have to cut out the concrete base.
It is currently Fri Jan 03, 2025 2:38 am
