Rotten skirting board next to back door advice needed
KJORO
by KJORO » Mon Mar 29, 2021 12:36 pm
Hello everyone. I’m after some advice please. I noticed the skirting board next to my back door appeared soft. I removed the board and underneath found various debris and some crumbling plaster. I’m no DIY expert and I’m just looking for some advice as to what I need to do to rectify the issue. I’ve added images for info. In the photo I’m pointing to what I think is the DPC. Thanks in advance :-)
Re: Rotten skirting board next to back door advice needed
by stoneyboy » Tue Mar 30, 2021 10:26 pm
Hi kjoro
It looks like the wavy black felt is the DPC in the wall, there is also a blue edge of the DPM under the floor. They clearly don’t join so damp will come up the gap. Suggest you use a wet render mix to level off the gap, then once this has set and dried a bit apply a number of coats of bitumen DPM to seal off the gap. It’s not going to be perfect but the alternative would involve relaying the floor.
It is currently Sun Jan 05, 2025 5:07 am
