running drainage under the foor boards?
sammyantha
by sammyantha » Sat Mar 14, 2009 9:19 pm
hi i want to move a kitchen fro the back of the house to the front. the only problem is that there is not any drainage at the front only at the back of the house , can i run it through the house under the floors? the house is a terace house in the middle so cant run outside and around the side... Help
by stoneyboy » Sun Mar 15, 2009 10:31 pm
sammyantha,
Provided you can get the necessary fall it will be OK. Make sure you fit an access T at the exit point so unblocking can be carried out if required.
sammyantha
by sammyantha » Mon Mar 16, 2009 12:20 am
fantastic thank you, what is a necessary fall?
by stoneyboy » Mon Mar 16, 2009 9:23 pm
sammyantha,
An absolute minimum would be 1 in 40, the problem you will have is supporting the pipe every 0.5m. You will also need to incorporate an Air Admitance Valve to prevent siphon action.
It is currently Tue Dec 03, 2024 12:36 am
