MOVING A PRIVATE DRAIN AND WATER BOARD PERMISSIONS
DUDE DIY
by DUDE DIY » Tue Jun 26, 2007 1:47 pm
I intend to move a private drain when I extended my kitchen. Just wanted advice on....1. is it best to get drainage plans or a survey from local water board? 2. Should i get permission to move my private drain in writting from the water board before starting work?...has anyone out there had problems with there local water board after they have completed simlar work. Thanks
jondeau
by jondeau » Fri Jun 29, 2007 9:54 am
It's your drain, you can do what you like with it.
I can't see the water company being interested.
On new housing builds the Building Control department of the local council checks and approves drains.......and if you really want to get involved with the beaurocracy ask them.
I can't recollect a single instance of small builders/plumbers ever bothering.
JD.
DUDE DIY
by DUDE DIY » Sun Jul 01, 2007 8:14 am
It is currently Mon Dec 02, 2024 5:30 pm
