Extending cables
stiz
Extending cables
by stiz » Fri Jul 13, 2007 11:59 am
I have some waist height sockets that I want to drop down to just above the skirting board. This means I need to extend the cable by approx 1 metre.
I know I can't just use choc blocks and bury them in the plaster, but can I do this if they are inside a choc box ? (taking the cable back into the ceiling and fitting a JB isn't really an option).
Many thanks
by sparx » Sat Jul 14, 2007 8:29 pm
Hi stiz, if back box is recessed in wall then if you crimp connections in box, using proper crimping tool, then are considered as 'fixed connections ' not requiring access & a thin cover plate over, using box screws should be OK
regards SPARX
stiz
by stiz » Mon Jul 16, 2007 8:22 am
Many thanks for this.
It is currently Tue Jan 07, 2025 3:08 am
