plug sockets in the kitchen
willy fixit
by willy fixit » Tue Sep 04, 2007 5:20 pm
Hi. I know there are regulations covering the placement of electrical sockets next to sinks in kitchens. However, if you have an earth leakage circuit breaker on your consumer unit, is it OK to have them fitted really close because it would be impossible to electocute yourself even if you wanted too. Does anyone have a definative answer?
by sparx » Tue Sep 04, 2007 10:16 pm
Hi. regs say no particular distance except that they must be 'suitable for their environment'. ie IP rated, also if not suitable for splashing as in standard domestic socket then should be at least 300mm from edge of sink/drainer. {From GN's & On-site guide}.
RCD's [elcb's] are not proof against electrocution!!! they are only a help, & unless regularly test tripped they do stick 'on', further they will not trip at all if you manage to connect yourself to Live & Neutral!
Regards
SPARX
It is currently Mon Jan 13, 2025 11:59 am
