Can Someone tell me What This Metal Wire Object is for?
JP38
by JP38 » Mon Oct 28, 2019 12:23 am
I found a metal wire object in my garden that must have come off a piece of equipment but I cannot work out which of the many pieces of equipment I have it could have come from. Can anyone help?
I would like to post an image but this does not appear possible.
The wire is about 1.5mm diameter. It is about 12cm long with the ends formed into circles - about 1.5cm in diameter at one end and 0.5 cm at the other. In the middle the wire is bent to form a shallow V shape.
If it is possible to post an image can someone tell me how? If not I hope this description is enough.
Re: Can Someone tell me What This Metal Wire Object is for?
by Mr White » Tue Oct 29, 2019 7:22 pm
What makes you think it is electrically related? Unless there is something that it is attached to, how is anyone going to know what it was for? It may be just a securing or safety wire.
To add an image you need to host it somewhere (On line photo storage of your choice) then you insert the link to it in your message via the Img link above the box you type your message.
It is currently Tue Jan 28, 2025 11:37 pm
