Max wattage on lighting circuit
jmcenhill
by jmcenhill » Mon Oct 15, 2007 8:08 am
I have just fitted a spotlight track. It has 200w worth of bulbs in, where the old one, which was low voltage, had 80w. Is there any chance I could overload the lighting ring. The other bulbs on the ring add up to 700w, and there are 2 extractor fans as well.
Cheers for help.
BLAKEY1963
Re: Max wattage on lighting circuit
by BLAKEY1963 » Mon Oct 15, 2007 5:48 pm
[quote="jmcenhill"]I have just fitted a spotlight track. It has 200w worth of bulbs in, where the old one, which was low voltage, had 80w. Is there any chance I could overload the lighting ring. The other bulbs on the ring add up to 700w, and there are 2 extractor fans as well.
Cheers for help.[/quote]
JMCENHILL
YOUR LIGHTING CIRCUIT IF ON A 6 AMP MCB , USING
230 V AS MAINS VOLTAGE WOULD ALLOW 1380 WATTS OF LIGHTING.
YOUR SPOTLIGHT TRACK WILL HAVE A MAXIMUM RATING ON IT ,
SO AS U HAVE PUT 200 WATT OF LAMPS INTO IT , IF THAT EQUALS
MAXIMUM RATING THEN U HAVE NOT EXCEEDED IT.
YOUR FANS DON T MAKE A GREAT DIFFERENCE TO THE TOTAL LOAD.
BLAKEY1963
It is currently Tue Jan 14, 2025 12:04 pm
