How to remove carpet from bathroom?
unitarea
by unitarea » Mon May 18, 2009 1:21 am
My upstairs bathroom is carpeted (wall to wall). I would like to refloor it by removing the carpet and putting something else which is more easy to keep clean and dry, such as linolium for example. My question is what sort of floorings are available, considering my second floor semi detached house dos not have concrete base, but some sort of wood. I think it is hardwood, but as I am not knowlegable in this area I am not sure if that would be the correct terminology. Thanks in advance for any suggestions.
by stoneyboy » Mon May 18, 2009 10:08 pm
unitarea,
If you are going to use lino (or similar thin material) you will have to cover the floor with hardboard - frequently fixed down. Consider using a laminated flooring but pick one designed for bathrooms.
bd3cc
by bd3cc » Mon May 18, 2009 10:48 pm
Sorry, but terminology is a problem here!
Do you live in a semi- detached house?
Is your bathroom on the 1st floor?
What age is your house?
unitarea
by unitarea » Wed May 20, 2009 10:37 pm
The bathroom is upstairs - i.e. 1st floor, so there is no concrete underneath only some sort of wooden floor. The house is from the early seventies period, georgian type, the kind with a loft which cannot be converted into another room.
floorlay
by floorlay » Sun May 24, 2009 10:46 am
if you use hardboard make sure it has been pree wetted and dried as moisture will buckle it if it hasent.then fit your vinyl
It is currently Wed Dec 25, 2024 4:46 am
