Alternative to PVA sealant
xmfclick
by xmfclick » Mon Jun 07, 2010 9:49 am
Like many other people, I want to lay a wood floor (engineered board) over a concrete slab. For various reasons, the slab has been screeded, but the work was not done very well and the screed is not perfectly flat. "Self-levelling compound" I hear you cry! All the advice I have seen says you should seal the (screed) with PVA before pouring the self-leveller. However, I am not in the UK and I have not seen PVA for sale here. What alternatives are there? (An old builder here suggested what they call "milk", which turns out to be a thin water/cement mix. Any old UK builders heard of this?)
Thanks in anticipation.
plasterite
Re: Alternative to PVA sealant
by plasterite » Mon Jun 21, 2010 2:37 pm
xmfclick wrote:Like many other people, I want to lay a wood floor (engineered board) over a concrete slab. For various reasons, the slab has been screeded, but the work was not done very well and the screed is not perfectly flat. "Self-levelling compound" I hear you cry! All the advice I have seen says you should seal the (screed) with PVA before pouring the self-leveller. However, I am not in the UK and I have not seen PVA for sale here. What alternatives are there? (An old builder here suggested what they call "milk", which turns out to be a thin water/cement mix. Any old UK builders heard of this?)
dont use pve if the floor gets damp it will emulsify and result in bond failure
mix and apply a 1:1 grout coat and screed over it when the grout is tacky
or
apply a coat of SBR bond 503
FEBOND SBR is a styrene-butadiene co-polymer latex specifically designed for use with cementitious mixes and as a reliable water resistant bonding agent.
SBR Bond is a latex based, water resistant bonding agent and admixture for use in areas subject to humidity, dampness and continuous water contact. Improves water resistance of cement mixtures by forming a reinforcing polymer that increases long term durability and flexibility of the mix on renderings and floor screeds.
It is currently Tue Dec 24, 2024 12:54 pm
