Laminate Flooring
Joe Delafield
Laminate Flooring
by Joe Delafield » Wed Mar 07, 2007 5:13 pm
I am laying a laminate floor and understand that the door architraves require trimming for a 'floating floor'. How do I cut the architrave and matching lamniate floor to ensure a neat job without any gaps?
thedoctor
by thedoctor » Wed Mar 07, 2007 6:04 pm
The easiest way is to use a tenon saw laying flat on the floor to tri the architrave Joe. If you would rather cut the flooring round the architrave then go to the projects section and look at the project called laying floor tiles. In there, there is a tool called a profile gauge which you press against the architrave to get the correct shape to cut from the floor.
Joe Delafield
Laminate Flooring
by Joe Delafield » Thu Mar 08, 2007 3:17 pm
I have used a tenon saw in the past fairly successfuly but it is a bit hard on the knuckles and have purchased a flexible pull saw hoping for better results. The problem with lock flooring is that you have to lift it slightly to get it to engage with the rest of the flooring but you cannot slip it under the architrave at the same time. If you get my meaning.
A profile gauge sounds a good investment for DIY projects generally.
Cut and Bruised
by Cut and Bruised » Mon Mar 12, 2007 8:33 pm
It would be a great idea if places that sold laminate flooring had a big sign saying:
"DON'T FIX THE SKIRTING BOARDS UNTIL YOU BUY AND FIT LAMINATE FLOORING"
thedoctor
by thedoctor » Fri Mar 16, 2007 1:13 pm
MANY OF THE ANSWERS TO YOUR POSTS CAN BE FOUND, WITH DIAGRAMS, IN THE DIYDOCTOR PROJECTS SECTION. CLICK HERE www.diydoctor.org.uk/projects.htm
It is currently Sat Jan 18, 2025 4:39 am
