gas valve outside
uk_ducati
gas valve outside
by uk_ducati » Wed Mar 25, 2009 10:27 pm
hi
could anybody tell me if it is legal to have a gas isolation valve fitted to a gas pipe outside. all other regs are ok eg pipe clips and sleaving through walls
cheers
paul
by htg engineer » Fri Mar 27, 2009 5:13 pm
It has to be a close as possible to where the pipe enters the property, was it is not possible to fit one internally ?
I would at least want a box over it, to stop people turning it off or being knocked to the off position. Also to protect from weather/rain etc.
htg
uk_ducati
by uk_ducati » Thu Apr 02, 2009 9:25 pm
hi
thanks for the reply
basically i was disconecting a gas fire and capping off the pipe that come through the wall so it could be decorated and the fire changed at a later date. there was no room to fit a tap internally and i assumed there was not one fitted but on filling the flue hole in i spotted a stop valve fitted outside and didnt know wether it was allowed or not. it was close to the entry point to the house.
cheers
paul
It is currently Fri Nov 15, 2024 6:24 am
