Options for internal insulation in bedroom
Aznar
by Aznar » Wed Oct 26, 2022 10:26 am
I am planning to internally insulate one bedroom (as a learning experience). I am thinking of something relatively thin... 3cm, maybe 4cm..
An easy choice would be to buy insulated plasterboards, but they are relatively expensive and I would waste 12.5mm on plasterboard.
Is it a totally crazy idea to install insulation boards directly on walls and then something on top to achieve smooth decorative surface? Something like cork or wall paper?
I would be very grateful for your suggestions.
Re: Options for internal insulation in bedroom
by stoneyboy » Thu Oct 27, 2022 10:49 pm
Hi aznar,
Probably not worth messing with individual materials, use foam backed plasterboard, sticky foam, tape the joins and two screws, job done!
It is currently Thu Jan 02, 2025 9:44 pm
