weep holes before render
mortarboard
by mortarboard » Thu Aug 21, 2008 7:14 am
I need to put weep holes over my door lintel in a wall that will be rendered. I intend to use the small vertical plastic ones to put in the vertical joints. Is it best to fit these now and stick them out 10 or 15mm to allow for the render or should I just leave gaps between the blocks and fit them later?
weep holes
by welsh brickie » Thu Aug 21, 2008 9:29 am
Fit them now and cover with tape.
If you try to fit them later you will probably damage the render
mortarboard
by mortarboard » Thu Aug 21, 2008 8:39 pm
Thanks w b
Is there a standard thickness for rendering?
(I'm going to get a pro to do my render and plaster)
weep holes
by welsh brickie » Fri Aug 22, 2008 2:52 pm
if you leave 10-15mm that will be fine
mortarboard
by mortarboard » Fri Aug 22, 2008 9:17 pm
Thanks for your help w b
It is currently Thu Jan 09, 2025 9:44 am
