hanging drywall/dat and dab
willi101
by willi101 » Sun Mar 16, 2008 7:03 pm
when dot and dabing to walls should there be a gap 25mm from the floor level or can the board fit top to bottom floor to ceiling?
kbrownie
by kbrownie » Thu Mar 20, 2008 12:17 pm
hi
it can rest on floor, but generally you find you need to lift the board a little so a nice tight joint at ceiling. I don't advise you to force board in if cutting a little to big as board will belly out!
Regards
KB
It is currently Sun Nov 24, 2024 2:44 am
