Seized up tap valve
yorkie48
Seized up tap valve
by yorkie48 » Tue Oct 28, 2008 10:00 pm
Hi there
I've found your project page on repairing a leaking tap very helpful, got the equipment I need, but cannot get the valve out of my kitchen tap, as it's seized up. I've tried a supposed releasing fluid to no avail. Any suggestions? It's a simple job that I should be able to do myself.
Thanks :x [/b]
bobplum
by bobplum » Wed Oct 29, 2008 9:36 pm
hi can you take the tap out from the sink/basin if so then place in a vice and go from there
bob
chris_on_tour2002
by chris_on_tour2002 » Wed Oct 29, 2008 10:53 pm
try turning it the other way (ie clockwise) to loosen it. some have reverse threads on them to prevent them coming loose during normal operation. you may think that you are loosening but might actually be tightening.
It is currently Sat Jan 11, 2025 7:59 am
