Tap Internal Spline Worn and how to Repair?
coverhill
by coverhill » Sat Sep 29, 2018 11:12 am
My house was built in 1914 and has many original and older features. The bath and taps is shown in the photo. I want to retain the taps and faucet but the internal spline of the cold tap has worn so that it no longer grips. If I substitute the hot tap handle there is no problem with opening the valve. Any advice please about what I can do about the internal spine of the cold tap please?
KitchenGuy
Re: Tap Internal Spline Worn and how to Repair?
by KitchenGuy » Sun Sep 30, 2018 3:05 am
It is a difficult job to do the repair you ask. It usually involves turning it down and fitting a splined sleeve over the top or a similar engineering solution. It would be easier to drill the head, thread and insert a grub screw.
All is not lost, if you want to do a bit of looking round you can replace the whole tap valve, stem and washer as one unit, it simply screws in and out. I have seen imperial ones on my travels so they are about. It looks something like the ones on this page.
https://www.notjusttaps.co.uk/tap-valves-washer-compression.html
Good luck
It is currently Thu Dec 26, 2024 2:22 pm
