Built in wall mounted thermostatic mixer in shower - can I just replace handles & front cover plate?
Paul&Amy
by Paul&Amy » Sat Feb 13, 2021 3:18 pm
We have a A3000 Trevi Therm built-in thermostatic mixer, about 17 years old. Images attached of existing unit. In the process of updating the bathroom - removing & replacing tiles, new walk in shower etc. To compliment the updated look, also want to replace the front cover plate & handles of the mixer (the bits you can see, basically). Everything else (location on the shower wall, cartridge & all mechanism concealed within the wall) to stay as is. Is this actually possible?
IMG_0758 (1).jpg (25.27 KiB) Viewed 2174 times
IMG_0756 (1).jpg (23.03 KiB) Viewed 2174 times
Re: Built in wall mounted thermostatic mixer in shower - can I just replace handles & front cover plate?
by stoneyboy » Mon Feb 15, 2021 2:20 pm
Hi paul&amy
There is no reason why you should not be able to replace these parts. The issue will be whether you can get replacements.
It is currently Mon Dec 23, 2024 10:22 am
