Correct way to connect two compression fittings together
JackG
by JackG » Mon Aug 09, 2021 3:07 pm
Hi. Stupid question I think. Hope I'm in the right place.
I have an isolation valve and an elbow both of which have 15mm compression fittings that would normally connect to copper pipe. What would be the correct fitting to use if I need to connect them directly to each other. Surely I don't have to use a short piece of pipe to accomplish this? (Newbie playing under the sink).
Thanks for any help.
Re: Correct way to connect two compression fittings together
by stoneyboy » Wed Aug 11, 2021 12:03 am
Hi jackg
You will need a 1/2” bsp female socket and since none of the threads will be tapered you will also need ptfe tape of thread sealant.
It is currently Mon Dec 23, 2024 7:49 am
