Does this undersink plumbing look ok?
sunglow777
by sunglow777 » Mon Apr 24, 2023 12:12 pm
I recently had some kitchen plumbing done by a handyman (leaking water heater replaced, new tap fitted, old washing machine disconnected).
Everything seems to be functioning more or less ok, but obviously the layout is a bit different now and I wanted to ask the experts here for their opinion as to whether it has been done properly.
One feature which looks odd is the white plastic upward-pointing pipe at the front — should anything be attached to this?
I also noticed the 'hot' flexible metal pipe coming out of the new water heater has a slight kink in it — is this likely to cause issues in the long term?
With sincere thanks
Re: Does this undersink plumbing look ok?
by stoneyboy » Tue Apr 25, 2023 11:41 pm
Hi sunglow777,
The white pipe pointing upwards could be used for a dishwasher or washing machine waste in the future. It’s the old washing machine waste connection and has been sealed off using the orange plastic.
The flexible should not have a kink in it - get it replaced with a longer flexible.
It is likely that the water heater should have a small pressure vessel in the pipe feeding it - this would be to stop ram pressure damaging the heater. Have a look at the installation instructions and see if one is specified.
sunglow777
by sunglow777 » Thu Apr 27, 2023 4:46 pm
Thanks very much. I greatly appreciate your advice.
It is currently Sun Dec 22, 2024 7:11 am
