How to orient elbow compression fitting correctly?
JStracks
by JStracks » Fri Apr 28, 2023 11:55 am
Hi all,
I assume there is probably an obvious solution to this, but I don't know it. On the right hand side I have an elbow fitting, which conveniently oriented perfectly when fully tightened, however the on the left side the fitting is facing upwards when fully tight. How can I fully tighten an elbow fitting on the left side and ensure it's oriented the way I need it? I don't want run without an elbow fitting, because I will mor sharp of a bend in the flexi hose than I am comfortable with.
Thanks for any help!
Image here: https://i.imgur.com/nsO4Pws.jpg
Re: How to orient elbow compression fitting correctly?
by stoneyboy » Sun Apr 30, 2023 9:58 pm
Hi jstracks,
You have two options - use enough ptfe tape so you get a sealing fit without tightening down onto the elbow shoulder, or, use a thread sealant - pick an anaerobic one which will seal almost instantly.
It is currently Sun Dec 22, 2024 7:02 am
