14Kg into plasterboard - no stud
jwilson
by jwilson » Tue Mar 04, 2008 10:10 am
Can anyone advise of how much weight teh most heavy duty plasterboard plugs can hold?
We have a 14kg cabinet which has 4 predrilled holes which will be goiing into internal plasterboard wall - cannot attache to stud partitions as not in the correct place.
Anyone any idea on the stregth of the heavy duty fixings or where i can get this info?
Jonathan
chris_on_tour2002
by chris_on_tour2002 » Thu Apr 03, 2008 3:53 pm
the fixings will have no problem at all hanging that sort of weight. the fixings are much stronger than the plasterboard, thats what you really need to be concerned about - can the plasterboard take the weight? probably, bearing in mind you will use at least 2 fixings (ergo, 7kg per fixing) but then it depends on what you are going to put into the cabinet once its up.
It is currently Sun Dec 22, 2024 2:19 pm
