I have a volkera combi boiler - I'm not sure what make off the top of my head, though I can go and find out
It is constantly losing pressure (one bath or 3 days is enough to go from 1.5bar, the recommended pressure, to 0), so I have to keep turning the pressure tap to keep it high enough to stop the pilot blowing out
Recently the pilot light started blowing out regardless of water pressure. The hot water is also no longer constantly hot - it cycles between hot and cold (or hot, then cold, then the boiler blows out and I have to go and relight it)
Finally, for some reason, it interferes with the record player if the heating is on, though I can cope with that.
Is there anything I can do to fix it, or do I need a new boiler?
