wall removal
yogi22kar
wall removal
by yogi22kar » Tue Aug 24, 2010 12:45 pm
I need to open space by removing wall between two reception rooms. This is 1930s semi detached house building. The wall is a solid brick wall and supports similar wall on top of it (that separates upstairs bedrooms). There is a wood burning fireplace in the corner of this wall in the first reception room. I am not sure if it is better to get rid of this fireplace as we do not use it. Also, do you know, if I would need a planning permission or any other approval for this work from the local council?
Any help will be highly appreciated. Thanks.
by stoneyboy » Fri Aug 27, 2010 1:12 am
yogi22kar,
You must get building regulations permission so will need plans for the structural elements.
It is currently Thu Jan 30, 2025 5:39 am
