Washing Machine Waste Advice
Bluerevolution
by Bluerevolution » Thu Jul 22, 2010 4:46 pm
Having a problem getting the required fall for my washing machine waste pipe as it will be running below ground floor level.
Can a waste pipe enter a gully below ground level, say if you cut a hole in the gully and run the 40mm pipe through. I'm thinking about 1-2 inches deep. (but above water line).
Any regs against this?
It is currently Fri Jan 10, 2025 10:53 pm
