Hello,
My boiler fires up ok when the heating timer calls it into action. It burns and heats the tank up to temperature and then the boiler shuts down. the pump keeps going though. Every now and then the boiler kicks in to 'top up the heat'. Should the pump not switch off after a few seconds and only run when the boiler calls? The pump switches off only when the programmer reaches its 'off' time. :shock:
Otherwise all is well!!!!
Any suggestions gratefully recieved.
Filip
