My neighbours (in the flat above) have installed a new BAXI Combi Boiler which does not always fire when the hot water tap is turned on. It does work sometimes.
They have had the plumber and the boiler manufacturer around to look at it and they believe that there is an air lock in the supply.
I have recently removed the old lead pipe supply that use to feed my flat and then up the wall to the neighbours.
At the entrance to the flat I have split the lead pipe and I have installed a 22mm copper pipe supply which runs directly to their flat. It does feeds their washing machine and the sink prior to feeding the boiler.
The problem is the neighbours believe that the problem is being caused by the plumbing which I dont believe is the problem. My boiler runs with no problems.
Can anyone offer any advice?
Thanks.
