what is sbr
rambo77
what is sbr
by rambo77 » Sun Jun 03, 2007 2:51 pm
what is sbr that you advised to use when rendering over pebbel dash as to pva
thedoctor
by thedoctor » Tue Jun 05, 2007 8:24 am
SBR Is short for Styrene Butadiene Rubber Latex it is designed to upgrade the bonding and waterproofing ability of Portland based cement mortars and screeds. Because of its huge tensile and flexural strength is can be mixed with samd and cement to enable a very thin application, sometimes as little as 5 to 7mm. It has incredible adhesion and allows a lower water content to be used for the same workability. Its available in all Builders merchants in 5 litre tubs which normally have mixing instructions for various applications on them.
It is currently Wed Jan 08, 2025 3:08 am
