Hi, we have:
3 bed house, 2 occupants with one main bath/shower and one en-suite bath;
25 year old Ideal conventional boiler with vented tank, and I am guessing original pipe work (solid ground floor) and radiators of 40 years; and
The tanks recovery time is ‘pants’ – I guess that is due to it being a gravity arrangement.
As the boiler cannot go on forever and as we are considering a new bathroom and would like good water pressure for showering we are considering what to do with the heating in system in general.
Would anyone have opinions in general and on:
Whether we should bite the bullet and have a total new system including replacement radiators etc with all new pipes or whether we could still utilise the existing pipes?
Which type of CHS – Combi based or an unvented system to obtain good hot water pressure? I suppose we could still have vented system but that would mean power shower pumps etc I think?
If we go combi route is it then best to go for a storage type combi (I am not keen on the idea of slugs of cold water flowing after you turn the hot water on and off, which I believe is a problem with basic combi boilers?) with a high hot water flow rate and if so which make and type to go for?
From my forays on websites the following would appear contenders:
Alpha CD50C;
Vaillant ecoTEC Plus 937 HE Power Store;
WorcesterBosch Greenstar Highflow 440; or
Glow-worm Ultrapower 100sxi.
I know it is a long first post but any thoughts you may have would be appreciated as it would be good to be forewarned before heading into the acquiring of quotes for the work.
Many thanks
