by collectors » Sun Sep 28, 2025 5:35 pm
by Mr White » Sun Sep 28, 2025 6:47 pm
by collectors » Mon Sep 29, 2025 6:17 am
Maybe i will put a volt amp meter on each string. It was only to keep an eye on things & they are cheap enough.Mr White wrote: ↑Sun Sep 28, 2025 6:47 pmYou have answered your own question. They are solar PANEL testers, not solar panel string testers. If You have a failing string, you need to know which panel is failing, using a solar panel tester lets you test each panel, so you can easily find the offending panel.
by Mr White » Wed Oct 01, 2025 2:32 pm
