Why Would my Hot Water Cylinder Start Venting?
Danholker
by Danholker » Fri Jun 22, 2018 11:27 am
Hi. Does anyone know why my hot water cylinder has started venting? It's pouring hot water down the drain which seems like a lot of waste.
dennispalmer
Re: Why Would my Hot Water Cylinder Start Venting?
by dennispalmer » Thu Jul 05, 2018 3:29 pm
There are mainly two reason behind the water heater cylinder venting as given below:
The pipework configuration is wrong and unless you have changed something.
A sludged up system causing a partial blockage making the open vent the easier route for the water to follow.
by ericmark » Tue Jul 31, 2018 7:10 pm
Normally caused by faulty thermostat over heating the water. However there are some weird and wonderful system, like the Willis so more than one reason.
