Will the same cistern fit?
Scotty1308
by Scotty1308 » Mon Aug 02, 2010 11:28 am
Had a bit of a toilet emergency over the weekend- cracked cistern! The guarantee covers us but will take 10 days. Cant pour water down the loo for that long because in typical bad timing style- we are getting married at the weekend and he bridal party is getting ready here, so need a working toilet!
The original toilet is a 'Peru Close Coupled Toilet - White' from Homebase, I have spotted a Cistern in Wickes which is a Close Coupled Cistern and has the same measurements. Will this work or does it have to be the exact same cistern?
plumbbob
by plumbbob » Mon Aug 02, 2010 9:33 pm
If you are thinking of a temporary fix, then you might get away with it coupling to the toilet.
However, the cold water inlet may be in a different position in the cistern so probably won't line up with the existing pipework. Also, some toilet pans restrict where the feed can be. Check this carefully before purchase.
It is currently Sat Jan 11, 2025 1:05 am
