I'm installing a worcesterbosch 24 ri, 3 coil hot water cylinder and solar panels with an s plan plus 2 zone system using horstmann RFT1 wireless programmable thermostats and a honeywell 10 way junction box. . . and
here lies my challenge. Wiring everything other than the stats appears self explanatory but the stats are doing my head in.
I assume the stat for the 2nd heating zone will be a simple 2 wire live common from the junction box terminal 1 and terminal 7 to where? and should it set up for 230v application or volt free
and the room stat for the 1st zone, . . . again do I set it up for 230 volt or volt free application and wires from terminals 2, 4 and 5 go where? you have no idea quite how much this is doing my head in . . . any advice will be welcome
