wiring sconces
jmiguel
wiring sconces
by jmiguel » Wed Jul 04, 2007 4:16 pm
Can someone please help me with the wiring of wall sconces. I don't have access to an outlet: Can I tap into a wire in the attic?
BLAKEY1963
Re: wiring sconces
by BLAKEY1963 » Wed Jul 04, 2007 10:42 pm
[quote="jmiguel"]Can someone please help me with the wiring of wall sconces. I don't have access to an outlet: Can I tap into a wire in the attic?[/quote]
JMIGUEL
PLEASE U ADVISE ME ? WHAT R U REFERRING TO AS WALL
SCONCES.
WHAT R THEY / WHAT IS IT ????????????
THANKS
BLAKEY1963
misterg
by misterg » Thu Jul 05, 2007 1:37 am
It's a bit like an uplighter, but usually a bit more fancy, e.g a candle
shape.
Basically wall lighting.
Regards
G
BLAKEY1963
by BLAKEY1963 » Thu Jul 05, 2007 9:50 am
[quote="misterg"]It's a bit like an uplighter, but usually a bit more fancy, e.g a candle
shape.
Regards
G[/quote]
MISTERG
THANK YOU I HAD NEVER HEARD OF THIS TERM BEFORE.
YOU HAVE BEEN MOST HELPFUL MISTERG.
JMIGUEL
NOW MISTERG HAS INFORMED ME FURTHER , I UNDERSTAND
THAT U WISH TO FIT WALL LIGHTING.
THERE IS A PROJECT SECTION WITH PICTURES ON DOC S
PROJECT SITE.( THAT COULD BE VERY INFORMATIVE.
IF THE LOFT IS ADJACENT TO WHERE U WANT TO FIT THE LIGHTS AS U SAY , THEN NORMALY IT WOULD MEAN TO LOCATE THE LOOP FEED OF THE LIGHTING CIRCUIT, AT THE NEAREST LIGHTING
POINT AND PUT A NEW CABLE FROM THERE TO A JOINT BOX.
OFF YOUR JOINT BOX COULD COME 2 CABLES , 1 FOR EACH WALL LIGHT.
IF THESE LIGHTS DO NOT HAVE INTEGRAL SWITCHES , THEN U WOULD NEED NEED TO USE A 3RD CABLE FOR A SWITCH WIRE.
AS I MENTIONED IN A FORUM QUESTION PREVIOUSLY , I WOULD ADVISE THIS WORK B DONE BY A REGISTERED ELECTRICIAN BECAUSE
BY ADDING ON TO A CIRCUIT U ARE INCREASING THE LOAD , AND
ALTERING ITS DESIGN AND TEST MEASUREMENTS ECT .
BLAKEY1963
It is currently Mon Jan 06, 2025 2:44 am
