Worcester Bosch 240 Combi
MRDAVEH
by MRDAVEH » Fri Feb 18, 2011 8:58 pm
I have a problem with my Worcester Bosch 240 Combi, when the heating is switched on it works fine. when the hot water taps are turned on, the water gets hot-ish eventually and at the same time the heating also comes on
What i do know is, the plunger in the diverter valve moves out and activates the 2 microswitches when the hot water taps are switched on and fires up the burners.
I noticed when only the heating is switched on the plunger dosen`t move but the burner starts fine and the heating system is ok.
I`ve also been told that there is a diaphragm inside the divert valve that could be knackered and is causing the problem.
CAN ANYONE HELP CONFIRMING THIS.
THANKS[/b]
by htg engineer » Mon Feb 21, 2011 8:11 pm
If the radiators get hot when running the hot tap - the diverter is at fault.
htg
MRDAVEH
by MRDAVEH » Mon Feb 21, 2011 8:24 pm
Hello
Thanks for the prompt reply,do you recomend new diverter valve, or would a new diaphragm be ok. I`ve seen them advertised on various plumbing sites for this model.
