Hope someone can help. Have a two year old Worcester Bosch boiler that is losing pressure.
Had WB come out and replace PRV under warranty but still got pressure drop.
However, outside there are TWO overflows from the boiler....one copper pipe from the PRV and one white plastic from somewhere else within the boiler. When the system is cold / not under pressure (heating and water off) and pressure is topped up to around 1.5 bar, the pressure drops slowly to zero over around a three hour period, with no visible water from the overflow outside. However if I then turn the heating and water on, after around 10 to 15 minutes, water can be seen gushing out of PLASTIC overflow and then stops. Then again after around 10 to 15 minutes it happens again. Anyone any idea what this problem is ? Faulty / split expansion tank ? Faulty / split heat exchanger ?
Thanks in advance
