Hi, hope you can help, i have a worcester bosch 24i junior combi boiler, that failed whilst on holiday, we have had an engineer out to service and check it over, he says it is the water pressure switch that has failed,
he was cheap to service & check it, but wants a small fortune to fix it, i know the part number of the switch i need, and worcester bosch says that once the switch is fitted the boiler will restart normally providing there are no other problems, my question is, is this something i am allowed to do myself ??, i know where the switch is located, and it does not interfere with the gas side of the boiler merely the water pressure side which is easy to drain and refill, i know this curtesy of a burst pipe once!!
thanks for your help, Hornet
