5 amp lamp dimming
wanthotweather
5 amp lamp dimming
by wanthotweather » Sun May 07, 2023 5:20 pm
Hello, is it possible to dim a light like this (which doesn’t have a dimmer switch) if I use a dimmable bulb and plug it into a 5 AMP plug with a dimmable light switch? Many thanks!
https://www.lights2go.co.uk/shop-by-pro ... CbEALw_wcB
Re: 5 amp lamp dimming
by Mr White » Sun May 07, 2023 10:12 pm
Make sure the dimmer switch you intend to use is LED lamp compatible (Not all dimmers can dim LED lamps) and as you said, make sure you buy a dimmable LED lamp. Then you are good to go.
You can use a "normal" 13A plug, but do change the fuse to a 3 amp fuse.
FYI the fuse is to protect the cable/flex NOT the light.
by ericmark » Mon May 08, 2023 6:39 pm
A dimming switch will only reduce the bulb output, where as a smart bulb you can dim and change the colour temperature and even the colour, so at under £10 for a smart bulb it is not worth using a dimming switch.
I did buy some years ago a couple of sets of socket adaptors with remote control, each set had two on/off and two dimming adaptors, the latter are today useless after we moved to LED.
It is currently Fri Feb 14, 2025 7:03 pm
