Access to sloping roof with a flat top
p.millson
by p.millson » Sat Jan 16, 2010 6:42 pm
My house is at the corner of a forked junction and is therefore wider at one end than the other. It has a conventional tiled sloping roof, but at the top there is a leaded flat section, which is about one metre wide at one end and two metres at the other.
My question is: how can I (or anyone else) get access to the roof for repair when the hook on a roofing ladder is too narrow to fit over the apex of the roof? Is a scaffolding tower going to be necessary every time I need to replace a tile (which is quite often as the roof is old)? Does anyone have any suggestions? I don't suppose there is some sort of special roof ladder that will be safe to use with my roof?
Peter
by stoneyboy » Tue Jan 19, 2010 10:50 pm
p.millson,
Sounds like you will need the scaffold tower every time.
If the tiles on your roof are that old a conventional roof ladder will probably break even more tiles where the support bars touch the roof.
It is currently Fri Jan 31, 2025 2:27 am
