Best Shower system for the loft
Saima786
by Saima786 » Thu Jul 08, 2010 3:50 pm
Pls can anyone advise me on the following. Have just had a Vailant Combi installed and realised the pressure is not as good as old Loft tank system. But its OK. Now here is the issue. I am having a loft Conversion with an Toliet/Shower and Hand Basin. We have one shower/bathroon in 1st floor.
I don’t want any water pressure issues if both showers are run. Should I installed a Ekectric shower in loft instead of connection to Combi Bolier. Any other suggestions
Many thanks
Sims
by htg engineer » Sat Jul 10, 2010 7:40 pm
As the combi runs off mains cold water, if the hot water flow/pressure is poor unless there's a problem with the boiler then the cold water wont be much better.
Electric or thermostatic mixer - if the flow rate or pressure on hot and cold is poor - you'll have very poor shower.
htg
TheDoctor4
Help from DIY Doctor!
by TheDoctor4 » Thu Jul 22, 2010 9:32 pm
If you would like to find a reliable, insured and vetted tradesman in your area why not click through to the Find a Tradesman area of DIY Doctor: https://www.diydoctor.org.uk/find_tradesmen/ , complete the form and receive up to 5 FREE quotes
It is currently Fri Jan 10, 2025 11:06 pm
