Evening all,
I'm working on a renovation property, with a new boiler/cylinder installation (also with 3x zone valves for two radiator zones and cylinder heating). Photo in the attachment.
The query I'm throwing out there regards cable supports. Considering this is an exposed surface - should I be running cable trays and stand-off brackets (the green line) with stainless table ties, to hold the cabling down across the top of the CH pipework (at roughly 50mm air-gap)?
Wiring centre and nest heat-links will be in the red and blue positions.
I'm trying to bridge the immersion heater cabling across to the right side wall also (those two sockets are on a single line to the consumer, and not on a ring circuit).
Will be getting this cabling done professionally - but just throwing it out there, as I know the cable support regs have recently changed, so thought and opinions welcome!
