Can a gas fitting be used on a mains water supply?
8 posts   •   Page 1 of 1
lone007ranger
by lone007ranger » Mon Jan 21, 2008 11:50 am
Hi there...
I'm thinking of having a friend of mine put in a second-hand bath for me. I only have a shower at the moment.
I wonder if a standard 15mm gas cut-off tap in brass could be used as the isolator valve for the cold water supply to the bath? If it's gass tight then presumable its also water tight?
Cheers!
Rik
rosebery
by rosebery » Mon Jan 21, 2008 12:43 pm
No. First the construction is all wrong and second the pressure in a water pipe is far greater than in a gas pipe. Both add up to "it won't work".
I wonder why you would want to do this? For the sake of a couple of quid?
In any event if you have a gravity water system then the bath should be piped in 22mm NOT 15. You can get away with 15mm if you have a combi boiler as your system will be at mains pressure.
rosebery
by rosebery » Mon Jan 21, 2008 12:45 pm
should have added - how are you proposing to isolate the hot supply?
nitro23456
by nitro23456 » Mon Jan 21, 2008 12:49 pm
baths should be 22mm piping.
bobplum
by bobplum » Mon Jan 21, 2008 1:50 pm
i suppose it could but for £1.50 why not just by a balofix valve from a plumbers merchant
bob
chris_on_tour2002
by chris_on_tour2002 » Mon Jan 21, 2008 5:51 pm
why would you even want to? the correct fitting costs nothing and is probably gonna be a lot easier to install as its designed for the job. stop being so tight! spend 2 quid and do it properly ;)
lone007ranger
Thanks folk for putting me straight !
by lone007ranger » Mon Jan 21, 2008 9:40 pm
Thanks folk for sorting my query. The gas tap has gone into a drawer and I'll purchase the correct isolator tomorrow. Regards Rik
thedoctor
by thedoctor » Mon Jan 21, 2008 9:46 pm
No facilities for uploading images yet but we are working on it !! Doc
It is currently Wed Feb 05, 2025 5:50 pm
