catflap
davidjan
catflap
by davidjan » Sun May 20, 2007 11:05 pm
How do I remove a moulded upvc door panel and fit a flat panel so that I can install a catflap?
thedoctor
by thedoctor » Wed May 23, 2007 7:43 am
The beads holding in the panel will prise out using a sharp chisel David. Start in the centre of a bead and lever it out a little, place somethiung behind it and move the chisel or scraper along. The bead will then pop out.
It is currently Fri Jul 10, 2026 8:06 am
