by NormanNovice »
Thu Oct 18, 2007 10:35 pm
Thanks Heating Doctor
I’ve read my DIY books and it doesn’t appear too difficult to move the pump???
I’ve already bought a new pump, as the existing one seemed knackered!
What I believe I need to do is remove the existing pump and replace it with a new length of pipe and 2 new compression joints??
And then I need to cut out a piece from the pipe running to the 1st radiator – attach 2 new valves to both sides of the valves and then attach them using 2 compression joints to the pipe?
I just wanted to check a few things before I start.
On my old system I used to have a T valve but there does not appear to be one on this system?
And I wanted to clarify my pipe work
1. There’s a pipe coming from under the floorboards – the pump is attached to this and just before entering the lower right hand side of the boiler a pipe from the C/H header tank water feed joins. (This C/H water feed pipe also goes into the bottom of the H/W tank upstairs)
2. There’s a pipe that comes out of the top of the boiler and this appears to be the (C/H Water tank over flow – is this called the vent?) It also goes into the middle of the hot water
3. This is the pipe I believe I need to cut into – It comes from the left hand side of the boiler and goes upstairs under the H/W tank I don’t think it goes into the H/W but off to the 1st radiator – I will lift the floorboards to check!
Does this all seem correct??
With regards to the Sols I’m afraid of throwing away good money paying a solicitor to try to get them to pay for the repairs – it could be a long drawn out fight and there’s no guarantee that I will get them to pay but I’ll have to pay the solicitor.
I really appreciate your help – thanks again
