Hi all, I'm new and don;t have experience on central heating (CH).
From what I read, i was thinking of installing a CH system without a boiler. Here's a description of what's in my mind:
I'm planning of having 2 raditors installed (downstairs and upstairs) and 1 water gas heater. The idea is to get the radiators connected directly in a closed loop to water heater via a circulation pump. Hot water will be delivered from the output of the water heating and the return lines will be fed to the inlet of the water heater. A non return valve must be fitted on the mains supply as not to pump water back. The mains supply will be fed from a water tank upstairs (2nd floor). (Water tank is used to supply both hot and cold water). Pump will work according to the thermostat control on each radiator.
Also the same water heater will be connected to the water taps in kitchen and bathroom.
Now, anybody think that this sytem will work? Will I have enough heat to warm up the house, or it's just waste of money or even a time bomb? If so please explain why?
Thanks very much
John
