Low voltage vs mains downlighters
misterg
by misterg » Sun Jul 08, 2007 10:43 pm
I bought some mains downlighters to fit myself, as I didn't want to worry about Part P. Other than that what are the advantages and disadvantages of mains and low voltage?
Unfortunately the lighting circuit wiring was in such a state, rubber insulated and hard as a rock, I decided a rewire was in order.
I called in a qualified electrician for a quote and he suggested using low voltage lights instead. He'll be fitting them now as part of the whole circuit rewire.
Should I swap the mains ones for low voltage?
Mister G
by sparx » Mon Jul 09, 2007 10:37 am
Hi misterg, no real differences 20watts is 20 watts wether 240v at low current or 12v at high current, main diffs are limits on distance from transformer if using several lv lights on 1 trnsf. cost more for lv ones with individual trnsfs. but only got 12v at light so slightly safer but personally I won't fit lv ones as too many probs,
regards SPARX
misterg
by misterg » Mon Jul 09, 2007 11:39 pm
Thanks again Sparx.
Then I'll stick with what i've got.
Mister G
It is currently Sun Jan 12, 2025 9:53 am
