Lower in Flooring in Attached Garage Conversion
110sb
by 110sb » Sat Apr 17, 2021 11:29 pm
I am wanting to convert my attached single story garage into a utility space and an office space.
In the utility space I want to put a shower but would have very little headroom once I've damp proofed and insulated the current floor. The floor is typical concrete slab. Can anyone advise if I would be able to excavate the floor in the proposed utility space then create a floating floor at depth lower than current slab? What would be needed to get it passed by building control?
Thank you in advance.
Re: Lower in Flooring in Attached Garage Conversion
by stoneyboy » Sun Apr 18, 2021 9:57 pm
Hi 110sb
With luck you will be able to dig down to the depth of the existing house foundations, form a new sub floor and build retaining walls as required before forming a new suspended floor.
It’s a matter of doing some exploratory digging and then agreeing with the BI how to proceed. Suggest you do this using the building notice route.
110sb
by 110sb » Sat Apr 24, 2021 11:16 am
Thank you for the reply.
